was my friend! Although I tried it first, Babelfish didn't work too well.
I wanted to use ShotGenius and realized that if I tranlated the "lang" file, that the program was then translated
I have pasted the english version below, I have not had any problems (although I have not worked a lot w/ the program extensively yet). I hope that someone else can find it useful also.
[shotgenius_it]
100=ShotGenius
110=WinInizio
120=http://www.wininizio.it
130=ZipGenius
140=http://www.zipgenius.it
145=Capture executed!
150=Image saved as
160=Connected to
170=connected to the server
180=disconnected
190=bytes transferred
200=Sending completed successfully
210=sent to
220=Sending failed
230=Time expired to send.
240=Member FTP
250=Image attached to the e-mail from ShotGenius
260=Keys for the capture of the screen…
270=Full screen
280=Display Area
290=Active window
300=Timed Capture
310=Options…
320=Extension keys for the capture
330=Exit
335=General
340=Buttons
350=Capture full screen:
360=Capture screen area:
370=Capture the active window:
380=Start/stop capture time:
390=Settings files
400=Save image as:
410=Filename:
420=Add date / time to filename
430=Add user name to the file name
440=Save file in:
445=Advanced
450=Various settings
460=Run sound capture
470=Show balloon catches (Windows 2000/XP/2003/Vista)
480=Run ShotGenius when Windows starts
490=Final Action:
500=Settings capture time
510=Capture screen every:
520=minute
530=second
540=Image quality settings
550=JPEG compression
560=Quality PNG
570=None
580=Submit via FTP
590=Send via e-mail
600=Information
610=Choose folder…
620=Please it indicates in which folder you want to save the captured images.
630=Compress in ZIP format with ZipGenius
640=Compress in 7-zip with ZipGenius
650=FTP server address(ftp:// not required):
660=Anonymous Access
670=Username:
680=Password:
690=Port (default 21):
700=Remote Destination Folder:
710=Passive connection (PASV)
720=FTP settings
730=Save to clipboard
740=Save to file
750=Image copied to the clipboard
760=The capture timer is not available when saving to clipboard.
770=Change capture mode:
780=Capture to file.
790=Capture to the clipboard.
800=Change capture mode:
810=Methods of saving.
820=Function not available.
