I'm using the latest version of ZipGenius, version 6.3.2.3110.
I have a zip file I create an SFX of. The SFX extracts to %temp%. In previous versions this worked perfectly, but now it does not expand %temp% to the system temp folder, it simply creates a folder called "%temp%" in the same location as the SFX file is located. For example: If the SFX file C:\btest.exe is run, it will extract into the "C:\%temp%" folder instead of the systems temp folder.
If I type %temp% in a command window on the system, I get 'C:\DOCUME~1\E\LOCALS~1\Temp', so the %temp% shortcut is valid.
Here is my sof-file:
[SFX]
Title=Extracting Installation Files
MsgText=
MsgType=0
Autorun=0
RunFile=
AskAutorun=0
SelfStarting=0
DestPath=%temp%
DestSubPath=Safe_To_Delete
OvrType=1
HideOvrBox=1
SelectFile=0
ShowSuccessMsg=0
ExpandEnvVars=1
HideFileList=0
AllowCancel=1
Icon=C:\MyIcon.ico
Post modificato da edvard il 11 May 2012 - 08:11 AM
Aggiungi Risposta
