smaragdus
Zipgenius 6.3.2.3115 - No Shell Integration.
Hi there,
I installed ZipGenius version 6.3.2.3115 (I tested both the Standard and the Suite editions) but it failed to integrate to Windows shell- my system- Windows 8.1 x64. Without shell integration ZipGenius has little use for me.
Regards
Ospite
Stai commentando come visitatore. Se sei registrato effettua l'accesso.
Rispondi a questa discussione...
×   Hai incollato del testo con formattazione.   Rimuovi formattazione
×   Your link has been automatically embedded.   Display as a link instead
