Inviato March 22, 2010 We are finally proud to announce the availability of the BETA 1 version of the "64 bit shell extensions pack" for ZipGenius. This package works like an update for ZipGenius and it can be used only on 64 bit versions of Windows (Win XP / Vista / 7). If you have ZipGenius already installed, just download this setup file and execute it;if not, download and install ZipGenius first, then proceed with the shell extension pack setup. This package will allow you to use ZipGenius shell context menu and .ZIP file drop handler in 64 bit operating systems. WARNING: this is BETA software! It may cause your system to become unstable or not responding and its usage could lead to data losses, damage and/or injuries. By downloading and installing this package, you agree to install a not finished and not completely tested software, and you agree to take the risk of doing this. WinInizio.it Software is not liable for any kind of data losses, damages, injuries you may receive. DOWNLOAD Condividi questo messaggio Link di questo messaggio Condividi su altri siti
