Inviato November 23, 2012 When I right-click on a file to compress it, and choose ZipGenius / Create archive with options, the compression level box is always blank. I have to select something, or the file is saved uncompressed. I just downloaded the update to v6.3.2.3110, but it makes no difference. I looked for an option that might change this setting, but I can't find anything except Advanced Settings, Shell Integration, Set compression level, which is set to Max Compression. Suggestions on how to get the compression level set correctly? Cita Condividi questo messaggio Link di questo messaggio Condividi su altri siti
