Inviato June 7, 2013 Introduction In the last blog entry I introduced some of the features in the post editor in IPS Social Suite 4.0. In this blog entry I'd like to show you the uploading features in the editor. Using the "Image" and "Attachment" dialogs Along the bottom of the editor there are two buttons that deal with uploading files: image and attachments. Both present a dialog which looks like this: We decided to keep both an images and an attachments dialog as users wanting to insert an image will naturally look for the "Image" button - if however, you upload an image to the attachments dialog, it will work completely as expected. The upload panel here is based on HTML5 which supports drag and drop uploading, if your browser doesn't support this, it will use Flash, Silverlight or Google Gears if you have any of those installed, and if not it will fallback to a HTML4 & JavaScript implementation (none of these support drag and drop, but instead you click the "Choose Files" button just as you do now - the label in the box will change to reflect this). Uploaded files then show below the box (images will get a preview), and you can click on any to add them into the editor, or click the "Insert All" button. When you insert an attachment into the editor, it displays either the image if it's an image, or a link if it's anything else, just as it will actually appear in the post (rather than the current " " tag). You can also of course delete the attachment, which will automatically remove it from the editor if you've already inserted it. Video Demonstration Quick drag-and-drop In addition to interacting with the panels, if you're using a supported browser, you can drag and drop straight into the editor. It will automatically figure out whether the uploaded file(s) are images or other files and add them to the appropriate panel automatically. Video Demonstration Image URLs In the image panel, there is an additional "From URL" tab which allows you to insert an image from a URL, as you type the URL a preview is shown, and you can optionally link to the image. Video Demonstration My Files In IP.Board currently, there is a "My Media" button which allows you to insert content submitted either in other posts or elsewhere in the community (images in IP.Gallery or files in IP.Downloads for example) into the editor. In 4.0, this feature is found in the images and attachments dialogs. Just with normal attachments, the content is inserted as it will be shown rather than the current " " tag. Conclusion Please let us know what you think of the uploading features in the comments. Remember though that we're only half way through our series on the 4.0 editor. In my next blog entry I'll be talking about customising the editor and the place of BBCode. Attached Thumbnails View the full article View the full article Condividi questo messaggio Link di questo messaggio Condividi su altri siti
